Edited highlighted knife numbers & trick pic
I highlighted the stamped numbers so that they stand out. I had to take them off the photo with editing software and then make darker and put back on. If you look closely you can see it is not quite right but Id rather have it this way as the PS0001 was hardly visible at all previously.
The Second photo has something wrong with it?? Id be interested if anyone would like take a guess at what is wrong??
Regards Tim
The two knives toward the centre on the lower photo with the scrolled bolsters are not scrolled the scrolling has been put on over the plain brass only in the photo.
Tim
You are too good with that editing, Tim! You could wreak havoc on Ebay! For a short time anyway.
If you don't mind, what does the BC on the tangstamp mean, on the fifth knife, 1st photo??
Boy's Club. Boone & Crockett. Big Cutter. Oh, ok... Bear Cult. One of the Tribute To Native Americans series.
Photocredit: I. Stoleit
Thanks Waynorth
Yes Im almost certain they are correct, it means Bear Cult although the handle material is not the same as the bear cult knives Ive seen, i suspect they probably thought of using a slightly different material in the handles and changed there mind for some reason as it is very different when handled, almost looks like some type of marble.
Im working outide at present on photographing my Pearl Harbour Bowie together with my other bowie (it is fun !!) I might post pic when Im done.
Thanks for clearing that up with the BC Irv as Id wondered for a long time what it was.
Regards Tim
