EDM stones
Started using EDM stones for hand sanding knives and I really like how they work.
Currently I am using Gesswein MoldMaker stones which are SiC. I really like the balance of wear and breaking down up to the 320 grit but at 400 grit and above the stones seem to have a harder bond and are not breaking down much so I am getting a loading issue.
Any recommendations or insight would be great.
I keep my stones in a tuperware of transmission fluid. Didn't pick TF on purpose, I just happened to have some laying around. Works great, but certainly not the only option.
This is the way with EDM stones. There are cheaper lappers out there but I’ve never tried them. I usually use my stones cut down to 1”
Madahu, Abrasive Tools - Pneumatic Tools TU-06 Air Lapper Turbolap Lapping Grinding Tools Turbolap Linear Saw http LINK REMOVED
Madahu, Abrasive Tools - Pneumatic Tools TU-06 Air Lapper Turbolap Lapping Grinding Tools Turbolap Linear Saw https://a.co/d/2dKqlIb
Roger,
Do you have a good method to cut them down cleanly? I’ve wanted to size mine as well but haven’t tried yet.
I compared 3 stones from Boride on 63hrc magnacut... The cs-hd were amazing and is my go to stone now. They sell an entire sample pack of that stone that goes from like 120-1200.
I do think SiC stones work well. The cs-hd is Borides hard bonded SiC line of stones. I am thinking for higher grits a softer bond might work better for me so something like the cs-m when I get to the 400 grit stone and above.
Advertising without appropriate paid subscription
I got this handy set from Falcon. All varieties of hard and soft stones.
LINK REMOVED
Rodger - PLEASE DO NOT POST LINKS TO NON-FORUM MEMBER SUPPLIERS
Boride Engineered Abrasives has a new alumina EDM stone:
The AS-9 PLUS is an enhanced version of our popular AS-9 stone. It was engineered to produce the same fast, smooth cutting action you can expect from the AS-9, but with superior finishing capabilities. Manufactured using premium aluminum oxide grain, the special formulation of the AS-9 PLUS produces wider scratches on the mold surface which results in an overall smoother and more brilliant finish.
Any experience with these yet, or are silicon carbide stones universally preferred?
