Efficiency In Tool Selection: A Method
FortyTwoBlades
Baryonyx walkeri
Dealer / Materials Provider
Over my years of edged tool use, experimentation, and study, I've tried all sorts of items of widely different quality, price, and features. I'm often asked to weigh in on matching a user to a particular tool, and while I've often referenced my methodology of tool selection in the process of this match-making process I haven't written it down formally until now. While this is a "living process" that will continue to see further tweaking and refinement over time, I think it will serve as a handy reference for others, and it's about time I put it all down in words.
Note that while this method is written with edged tools as the specific focus, the method may be extended equally to most other forms of gear.
Step 1: Defining Your Purpose
The very first stage in selecting the right tool for your purposes is to very clearly identify and define those purposes. What do you want the tool to do? Note that this can even be so superficial a reason as needing to "scratch the buying itch" to a very wide range of diverse and specific tasks. For instance, do you plan on using the knife or tool for slicing? For carving wood? Food preparation? Batoning? Chopping? Do you need all of the functions in one tool, or can they be spread out amongst two or more? If “scratching the itch” what functional gaps do you have in your present arsenal? It may help to write these tasks down as you think about the situations you might face either on purpose or by happenstance when using the tool.
Once those tasks have been identified, it’s time to put them in prioritized order. Think how frequently you’ll be performing each of those tasks, and number them in order of importance. Since different tasks may have conflicting requirements, this will help you determine how much weight to give each task when attempting to balance between them to establish an optimum compromise.
Lastly, consider the environments you’ll be using the tool in. How are you getting the tool there? How are you storing it? Is it for use around the home, or are you carrying it on extended backpacking trip with a lot of other gear? This will help you narrow in on the ideal balance between function and ease of portability/storage.
Step 2: Translating Functions Into Features
The next step is to take each of those tasks and to translate it into features that provide the benefits you’re looking for. Don’t worry yet if some of those characteristics are in direct opposition to one another--take each task individually. For instance, if you plan on skinning large game, a lot of belly to the edge is usually desirable for making long sweeping cuts. If cutting root vegetables like carrots or potatoes a very thin blade is desirable for gliding through the resistant and easily fractured material. For drilling, a centered point that isn’t too delicate is of benefit. If prying, lateral stiffness and toughness are both required. If chopping or batoning, shock resistance must be given consideration. For detailed or precision work a shorter blade and/or a very fine point are often useful. Write down as many specifications as you can think of for each task or purpose.
Do the same for your environmental concerns. Is bigger or smaller better? Heavier or lighter? Is a sheath or edge cover required? If so, what should it be made of and why? What kind of retention method? Carry method?
Step 3: Balancing Your Antipodes
This is where things really start to take shape. Go through your list of features and find any criteria that oppose each other and rewrite them in antipodes (an-TIP-oh-dees) or paired opposites, with the prioritized one of the two listed first. These pairs are your “neither too this, nor too that” groupings and you must consider how to appropriately balance between the two aspects. Each of these antipodes gets 10 “points” you can divide between the two opposing qualities. Assign these points to the pairs in a way that best represents your needs out of the tool and you’ll know the approximate amount of emphasis that each aspect will receive. For instance, you may be looking for a chopping tool for ultralight backpacking, which will result in at least two antipodes: light/heavy and long/short. You may decide that light overall weight is more important than the advantage in use given by greater weight, and choose a 7:3 balance in that respect, choosing to gain back some chopping power by increasing length a little at the expense of the tool being less easy to pack, selecting a 6:4 balance for that pair.
Step 4: Interpret Your Results
Once you’re finished balancing your antipodes, look over your results and try to think of what a tool that meets all of your criteria would look like. If it helps, try reading the criteria aloud as if describing it to someone else. For instance, based on the limited criteria provided as an example in Step 3 above, we might be looking at something like a long handled lightweight tomahawk. If other criteria were added, like the ability to clear vegetation and brush, the description might more resemble a tip-weighted machete. Once you’ve formed a mental image of the sort of tool you’re looking for (or drawn a sketch if you prefer) we’re ready for the next step.
Step 5: Price vs. Performance
Now that you know what you’re looking for as your ideal, consider what you’re willing or able to spend. Are you able to spring for a top-of-the-line custom that exactly meets your criteria, or do you need/want to look at standard commercial production models? With as many, many knives and tools as there are on the market today, chances are you can find a tool “off the shelf” that fits your purposes nicely. By carefully considering and referencing your list of prioritized criteria you may establish how best to maximize your performance per dollar spent. As with all expenses, there is a point of diminishing returns where each unit of increased performance begins to cost more and more, giving you less and less benefit. In a performance-optimized purchase every area of your criteria will be brought, in weighted proportion, as close to the point of diminishing returns as possible before any excess funds are spent on non-critical features.
Imagine, if you will, that much like in Step 3 you are assigning points to criteria of the tool. However, this time around you have to buy those points with dollars. In a given area of performance, the points per dollar will actually increase as you buy them--such as the first dollar buying you 1 point in that category, the next dollar spent in that category earning you 3 points, etc. until the points per dollar equalizes and then begins to diminish. That tipping point is your point of diminishing returns. Naturally your overall performance will therefore be very low if you sink all of your points into a single category and neglect others. However, if buying a non-custom tool, all of these points are already assigned for you and the total cost of those points is reflected in the purchase price. If buying a custom tool, by contrast, each point costs more because you are paying a premium for the privilege of being able to assign the points yourself with greater specificity. Research your options with diligence--the more choices you uncover the easier a time you will have in deciding on the best tool to purchase.
Step 6: Post-Purchase Reflection
The final step of the process. In spite of the fact that you have now purchased a tool, it must be acknowledged that this choice was made using your best judgment and experience at that one snapshot in time. Upon receipt of the tool, pay attention to how it functions for the intended tasks to either confirm or contradict the forecast you made of the tool’s performance. Depending on the tool there may be some learning curve involved, so reserve final judgment until you have become well familiar with it. Consciously think of how the balance of features could be further improved for your purposes. This information will add to your experiences and observations, allowing you to make better and more accurate forecasts in future purchases.
Looks like a well thought out theory. Not as much fun as " Dam that looks cool".
Honestly I think most of us subconsciously start with something like this but get sidetracked with emotions.
Good post.
Thanks. I do all of the above in my head when deciding on my purchases, but I know that many just think in a different way than I do and I figured that codifying the process might help some folks in finding tools that will provide them the greatest satisfaction. Buying a knife just because it looks cool feels good in the moment, and you feel excited when you open the box and play with it the first time, but if it never gets used, the pleasure usually stops right there. The job of any tool is to make the simple act of living a more pleasant experience, and a tool that (however humble it may look) helps you surmount challenges you experience in your daily life with ease provides the greatest satisfaction at the end of the day. :)
You said in your first post " identify and define those purposes." I feel this is where most often things get mucked up. A romantic notion of what can be done / who we might become takes over. We see a survival expert, Bush craft super star , tactical bad ass or something and run with it. I know I have.
In the past our ancestors did far more with far less then a 1/4" thick super steel blade that cost a car payment then most of us will do.
Just some thoughts off the top of my head & I still am going to get a Condor Solobolo. Not because I need it just want it.
So that's how you pronounce antipodes.
Great post.
I've read your post and have marveled that someone actually put that process down on "paper." As you did mention, it's primarily a "head" exercise. My steps are more in line with...
1. Gosh, what's that? Gee, it looks nice...
2. Blade-steel is good; I need good steel; don't know why...nice length for EDC, decent jimping; thin enough to slice...maybe.
3. Grip is long enough to fit my large hands, and not too thick. Ooooh, I hate fat grips.
4. Yeah, less than 5 ounces; decent-looking clip. I could do this.
5. Price is higher than nice...but if I sell off some of this other junk, I can do this.
6. Okay, yeah, I have four NIB in the bedroom just like it, but I like this one...a lot...
7. Good enough. Let's see...oh yeah...Paypal will work...pay it off sometime...don't tell mama...
Sonnydaze
Agreed. And there's nothing wrong with buying a tool "because I want to"--it's just all in recognizing that that's its intended purpose rather than the romantic notions blinding you to it. If you still end up feeling fine about the purchase when you realize you'll probably never actually use it for what it was designed for...that's totally fine! :D
Great post.
Hahaha--thanks. And yeah, a lot of folks would probably read it as "anti-poads" I imagine. :D
Sonnydaze
Exactly. I hope this approach will help folks end up with a few fewer knives gathering dust. :D
You're overthinking it...it's not rocket science. ;)
Well written post anyway.
The method's not rocket science. ;)
It's just instructions on how to methodically find what you need your tool(s) to actually do, identifying any contradicting requirements, and then striking a balance of features that gives you the most benefit with the least sacrifice for your needs and budget.
I certainly have some blades gathering dust due to uninformed choices. My choices tomorrow may well demonstrate that my choices today were not as informed as I thought they were. But, I don't get all hung up on this kind of thing. After a while, it is just about fun.
I think many people think that a cutting tool should be able to do everything well. It's just not the case. If you buy a hoe for the garden, it really doesn't do well digging a hole for a mail box, but I guess you could use it for that.
The woods craft use blades are most interesting to me. What used to be just knives or fixed blades are now woods craft or survival knives. Yeah, it's fun.
Like you, I go through a mental list of why I want a particular blade, but often my use definition is a bit fuzzy. Ultimately, half of them are just about "I wanted it". That is where I am with your Baryonyx machete. I want to get one, but I know I really don't need one. Sometimes you just have to go with a gut decision.
When I make my own decisions I do all of this informally in my head rather than mechanically going through it all as written. However, such visualization doesn't come naturally to a lot of folks which is why I suggested things like actually writing stuff down or voicing things out loud. If you feel like you can shortcut the mechanical aspects, do it! Also, note that "need" isn't even really part of the equation here. If you define your purpose as "I want a new toy that's different and interesting" then...that's your purpose! And you can then make your selection based on that set of criteria. :)
Very nice post! Very thought through process for ... tools :)
Now if I where to follow that for knives, I'd have 3. :/
I'm a bit more simple minded. My thought process runs toward...hmmm I need to cut something...this knife will do fine...I need to pry something...hmmm this pry bar will work... I need to bang something...c'mere sheep...oops thoughts ran amuck...meant to say...hmmm where is my hammer...
Remember--"just for fun" counts as a purpose! Strict need doesn't have to have anything to do with it! I have tons of knives and I do have some just gathering dust, and intend to sell them off whenever I get around to it, but the majority of my knives and related tools (I have around 30 machetes personally, for instance) are diversified so that each covers a range of use that's a little different from the others I have. Avoiding duplicates when they aren't needed is part of this process.
Hahaha--my thought process tends to be "I'm getting by with this tool right now, but I do X quite a lot and a different tool would make my life easier than this one is right now. What would that better tool be like?" Then I browse the internet for a bit until I find something that looks like what I'm searching for. Sometimes those items aren't even designed with that purpose in mind, but just so happen to fit the bill nicely. For instance, I use an Estwing long-handled geological pick in the winter for busting the ice on the water troughs for the horses and prying up the cinderblocks that act as tracks for the sliding barn doors when the frost moves them out of place.
Sometimes I will be just looking around. I will see a tool( knife) it might look nice but not for me. Nothing wrong with it just not for me. Or not something needed. So I move on. Then I will see it again & again. Start to read how great others think it is. Next thing I know I am on the bandwagon. Thinking about getting one. This might take a few weeks or go very slow over many months. So for I have not fell for the trap. At least not in a big way.
Your process is good but only if it is used honestly. Very easy to get caught up in the moment.
Thanks for this, FTB.
I'm trying to be more systematic and reasoned with my knife purchases; it's helpful to see a decision-making process laid out like this.
Indeed. Honesty to the self is, in fact, part of the intention of this method. As mentioned, it's totally fine to buy something "just for fun" but the point of defining your purposes is for you to clearly identify why you are looking for a knife or tool. Sometimes that reason is just 'cause you want a new toy, and that's fine as long as you realize that's the reason for the purchase! :)
You're very welcome--glad to know that it'll prove helpful for folks. :)
Very well thought out.Personally I think long and hard before I make decisions. Lol,at least now that I'm older. :o:)
:) I haven't thought about Huntz Hall and Leo Gorcey in... many years. I used to love The Bowery Boys.
It was an extinct pleasure to remind you.
I used to love the way Slip butchered the English language.
I really did read anti-poads though. I've learned many words through reading and didn't bother with pronunciation in too many cases.
