I have been making blades out of old saw blades. This has required annealing the tang to drill holes for the pins. At first I heated the tang with a propane torch till red hot and no longer magnetic. But results were inconsistent. (Assumed I needed to hold the heat longer) Next I heated to red hot and non magnetic, then jammed them into the dying charcoal brickettes after a BBQ, and left till morning. This seems to work 100%, however leaves substantial blue discoloration on the steel.
How is the best way to grind/ polish out the discoloration ? I’ve run through several grits of sandpaper, & tried metal polish. Just seems like it takes a lot of time.
Is there a better way to anneal without causing the discoloration?
if discoloration is inevitable, is there an efficient way to buff the metal back to bright ?
