If your blower has a universal brush type motor then one of those
router speed controls will work fine on it. It might be easier (and regardless of motor type) to just install a flap on the blower intake (such as Don Fogg does
here) or install some type of valve down line from the blower.
Regards,
Greg
Universal motors (copied from
here.):
What motors can be controlled?
Virtually all power tools and small appliances use so-called "universal" motors. These are "series wound" motors with a commutator and brushes. The "series wound" term refers to the fact that the motor armature and field windings are connected in series and this allows the motor to be run from AC or DC, ie, "universal".
Induction motors must not be used with this speed controller. So how do you make sure that your appliance is a universal motor and not an induction motor?
In many power tools you can easily determine that the motor has brushes and a commutator - you can see sparking from the brushes and that settles the matter. But if you can't see the brushes, you can also get a clue from the nameplate or the instruction booklet.
So how do you identify an induction motor? Most induction motors used in domestic appliances (eg, washing machines, fridges, water blasters, swimming pool pumps) will be 2-pole or 4-pole and always operate at a fixed speed. Typically this is 2850 RPM for a 2-pole unit or 1440 RPM for a 4-pole unit. Bench grinders typically use 2-pole induction motors.
