- May 9, 2004
I just finished wiring my new shop, I put in a subpanel, Ran a new grounding pole and wire, Ran the two hot wires and neutral from 200amp box to sub. Now I wired all my plugs the same, I'm not an electrician so I wired the white to the silver on the outlet and the Black to the Brass, and ground to the ground, I went to wally world and bought a circuit tester, and on every plug it says, Neutral/power reversed, Well I reversed the wires in the sub panel (For that circuit), and still same thing. If they were reversed, it should have fixed it when I reversed the power and neutral. So could it be just a bad tester, And will it really affect anything if I leave it the way it is, All plugs and switches work just fine, But that tester is driving me crazy.
Thanks
Thanks
