I'm moving into a new house, and I plan to have my shop in the current garage behind it. Currently the house(an old house) does not have anything electric besides lights and outlets and is running 3 circuits at 20 amps each(60 total). I plan on adding a water heater at some point in time. I was thinking about running a 100 amp 220 line under ground through a conduit to the shop.
Is 100 amps enough for the house?
Is 100 amps enough for the shop?
I plan on having a lathe, drill press, table saw, some grinder, and a welder. But not running at the same time...
The circuit box has a 200 amp main switch. Can I put a larger switch in? Or can I run the main lines from the power line under ground to a new box(that would be crazy wouldn't it?) I'm trying not to get a new meter at the shop, because they would have to put in a new pole. Whaddya think?
Thanks in advance. btw, I am prolly going to rewire the house anyways, the wires are ancient. So I'm willing to change things up if it is best...
