Don,
All the techniques you speak of should be in the owners manual, so people who purchase this unit would have a faster learning curve. Get back with me when you've tried the alcohol.
Fredetch, but I'll use alcohol on the next.
It is kind of worrying when the stiff green stencils raise up, but if it's taped all the way around so that it can't move, it has never caused a problem for me.
I've used my personalizer plus for many years.
I've found that these things always work for me:
First, tape the blade to a piece of brass sheet so it can't move. Apply the wire clip electrode to the brass plate, not the blade.
1. Tape all around the stencil with black electrician's tape. It won't pull the resist off the stencil when you remove it.
2. Wrap the pad around the end of the applicator and pull it tight with a rubber band.
3. Dampen the pad with electrolyte, then remove all the liquid with a paper towel.
4. Set the unit on "etch".
5. Set the dial at 2.5. This setting has always worked great fo me on any blade.
6. Hold the pad against the stencil for a few seconds, lift and see if the mark is completely black under the stencil. If not, repeat until the whole mark shows black.
7. Move the switch to "mark" and press for a second or so, lift away, repeat 4 or 5 times.
Yes, the main thing is not to use too much electrolyte, use the black tape, and don't use more than the 2.5 current setting on the dial. Don't fry the stencil and create too much heat.
Never clean the stencil with the cleaner. It will shorten the life of the stencil dramatically. Clean the blade with cleaner, clean the stencil with soap and water.
This always works great for me.[/QUOTE]
