- Dec 27, 2013
Hey guys, I thought you might think this is interesting.
This is an electron microscope image and chemical analysis of a piece of 6Al4V titanium alloy that was being forged and ground into a blade. It's a little piece of the tip that was cut off. In the image, you can see the straight lines of grinding, which is from a somewhat worn 120 grit belt - this is the bevel section. Above the strakes is a more ragged section, that is the flat, ground harshly with high pressure at 36 grit.
The blade in question and reason for the chemical analysis is here: https://www.bladeforums.com/threads...bird-airframe-titanium.2066626/#post-23412086
Kinda cool to see! :]
