- Jul 24, 2007
I like to do as much work on my blades as possible before HT, including a mirror polish. I was thinking, will it work well to use electropolishing to remove the burnt oil and get the polish back after HT?
I found that this Correction fluid work if you like me don t want to mess with that burn oil after quench .Help with decarb. too .After quench you can wipe it down as it is grease and blade is clean in secondsI like to do as much work on my blades as possible before HT, including a mirror polish. I was thinking, will it work well to use electropolishing to remove the burnt oil and get the polish back after HT?
What he is doing is basically the same as using Turco II (which I use on all carbon steel blades). It coats the blade and cuts down on decarb. It won't leave the surface shiny, however.
What decarb is ? It is the nightmare of everyone ....probably worse part of knife makingCould you quickly explain what decarb is? I haven’t quite wrapped my head around it.
Stacy, where are you sourcing Turco from?What he is doing is basically the same as using Turco II (which I use on all carbon steel blades). It coats the blade and cuts down on decarb. It won't leave the surface shiny, however.
Very informative, thank you.My last can of Turco II came from K&G, IIRC.
Decarb is the layer of surface steel that has had the carbon depleted (DEpleted CARBon). The high temperature and exposure to oxygen causes this. In a HT in a forge, it is the worst. It can go a good .020" in the surface. In normal HT in a HT oven. it is more like .010" deep. Using things like Brownells PBC, Tuurco II, white titanium paints ( Natlek's correction fluid), etc. will greatly reduce decarb.
Just looked it up. Turco II at K&G - $60 :
https://www.knifeandgun.com/SearchResults.asp?Search=turco&Submit=
It goes a long way, so that isn't as much as it seems.
One quart is almost one litre so 60 bucks is not to much .Will last long time to me .Correction fluid works but it is pricey compared to this Turco II . Is it easy to clean after quench this Turco , Stacy ?My last can of Turco II came from K&G, IIRC.
