- Aug 25, 2008
Anyone know when these will be out? I want one bad.
Also it sure does look like a William Henry.
This one caught my eye in the latest catalog too. :thumbup: It's a beauty, no question. The only concern I have is based upon my experience with the Boker Magnum Blitz. The Blitz is a button lock as well and is offered as an auto on the German market, but is "de-springed" for the US market. As a result of not having a strong coil spring exerting pressure on the blade in the closed position (trying to force it open), the blade drops down far enough into the frame that the edge rests against the middle standoff at the back of the handle, resulting in a dinged edge. I was able to fix mine by finding a black nylon bushing at the hardware store that had an inner diameter the same size as the standoff, sanding it to the right width, and then slipping it over the offending standoff. Now the edge rest against nylon rather than steel. Not a big deal on a $20 knife, but it would be a shame to have to similarly mod a much pricier knife. I'm not sure if this is common to Boker button locks that are made as manuals for the US market, or if it's just the Blitz, or if it's just my particular one, as the Blitz was my first and only button lock of any kind, but it's something worth considering. Maybe Terry can comment?
You're right. I should clarify. On the Blitz, or at least my particular one, while the lock does act as a stop as well as locking the blade in the closed position, it doesn't stop the blade quite soon enough to keep the edge from impacting the standoff. When the blade is closed you can grab the spine and lift the blade about 1/16" out of the handle until it the tang actually contacts the lock and stops moving. In other words, mucho play. What I was suggesting is that the spring in the auto version probably keeps enough outward tension on the blade to keep it fully pushed up against the lock when closed, rather than allowing it to drop that extra 1/16" and hit the standoff. Don't know if that makes sense or not.The button lock also doubles as the stop pin in the closed position. The blade would be in the same place weather the spring was in or not.
