Elmax steel on Jnats?
I'm planning on buying a king 1000/6000 stone, in conjunction with a spyderco ultra fine bench stone. I've mostly been stropping since, making some pretty convex edges. My question is, will such a Japanese stone cut well enough on a vanadium rich steel such as elmax? If someone could tell me the Rockwell of the abrasive in such a stone, it would be much appreciated, too. Thanks guys!
#217 in RyanW's 2014 Giveaway
King 1K/6K is a synthetic not natural waterstone. Abrasive is alumina (form of aluminum oxide). King waterstones work well on simple carbon knives, so so to lousy on high alloy knives. I recommend shapton glass or pro 1K & 6K for this Elmax (and other high alloy knives) knife. Shapton Waterstone has high density ceramic particles work as abrasive, which quite effective up to 6K.
I would certainly have bought shapton straight off the bat, if it weren't for my price restrictions. Do you have any recommendations in the 30-70 dollar range?
A tad over budget, spend $57 for a shapton 1K and $16 for DMT 4" replacement for aligner. if still need/desire later on, well buy shapton glass 6K.
However if you lean toward high-alloy future, buy DMT 8 E and 8 EE.
I think 1K grit is top(sweet spot) of the bell-curve in usage/utilization for those sharpen their own knives. 180-400 grit is a good fit for edge-scratcher non-knut users.
I know your not asking about the Chosera stones but here is my 2 cent's worth,I have a KME system and the Chosera and KME ceramic stones and I find that the Chosera stones work just fine on my ZT0560 and 0566 and get really sharp and can shave hair off my arm with the lightest touch.
Do you happen to have any opinion in the spyderco bench stones?
I went ahead and grabbed those Dmt stones.
Many brand/type of quality (non-diamond/cbn) waterstone will work fine for high alloy knives but usually become in-effective in higher grit range 7+K. You can test edge off these high grit (7K+) stones for durability by cut 3+ feets of thick cardboard then try to shave or slice newsprint afterward. a durable edge should pass the test because the presents of carbides on the apex(wear resistance) shield most of the matrix from cardboard abrasion for this short cutting duration.
I like spydero ceramic: medium & uf. Don't lap medium in spite its surface is not super flat but it cuts fast + use BKF to clean it. I mostly use my lapped 306UF as finishing grit for high end ($300-$1K) salon shears. However lately I relied on dmt E to fix a lot of worn out shears and some time just lightly strop after this stone/plate.
I use the 10000K Chosera on my ZT0566 and ZT0560 and you can see a grey slurry on the steel and on the stone,I know what you are saying that it's not going to remove as much metal as a 1000K or 5000K stone.I know I was surprised at how much the 10000K removed the first time I used and it was a fair amount.
I find the edge last's along time on my ZT's wether it's cutting cardboard or zipties off of something,I must say I'm really impressed with the ELMAX steel.
