So I was sharpening this custom fixed blade I have. It's a scandi-ground drop point, .098" thick and Elmax HT'd to 62 hrc. The main bevel grind is about 25 degrees inclusive.
Given these dimensions what kind of steel is it comparable? I ask because, versus 1095 I really don't see a HUGE amount of difference in edge retention. I'm wondering if this is because the blade is relatively thin and the grind also an acute angle. It definitely holds its eddge longer than 1095 or other mild steels but I expected it to be like, exponentioally better at edge holding.
I'm figuring since it's ground so acute that's the trade off? Better cutting performance than edge retention? I will say it's amazingly tough... I've accidentaly ran into a few staples during an odd-job I'd rather not detail, but long story short I put a LOT of force on a steel staple thinking it was just a wood splinter, and it barely dented the edge. From my experience using more mild steels if I had done the same with them, it would have been a much bigger deformation.
