"All things are permissible. Not all things are beneficial."
St. Paul was a tent maker by trade, so perhaps it was from his experience in fabrication that he learned just because you can do something doesn't mean that its a great idea.
This Flickr photo set documents a stove modification that combines an Emberlit stove with a Trangia burner resulting in a significant drop in burn time. But in the end, I'm not sure it's worth the hassle.
Here are the times for boiling 2 cups of water in the same conditions:
5:30 - Svea 123 (2:00 prime + 3:30 burn to boil)
5:30 - Trangia (Supercharged Mini pot holder and foil screen)
6:30 - Emberlit with wood
7:45 - Trangia flat on bottom of Emberlit and no windscreen
5:00 - Trangia in Emberlit with custom base and windscreen
There are two things to point out about these times. The first is that just shoving a Trangia burner into an Emberlit produces horrible times. Really horrible.
Second, this modification produces a noticeable improvement over both my Svea 123 (including the priming time) and my "Supercharged" Trangia Mini.
But in the end, it's too fiddly to deal with and I end up preferring to use Trangia Mini on it's own.
In any event, here are the details in case you're interested. I tried to address this by taking some cues from the Clickstand and addressing 2 issues: the distance from the burner to the pot and the loss of heat to the wind.
Emberlit with Trangia & Windscreen by Pinnah, on Flickr
There are 2 "things" needed for this: a base to raise the Trangia burner closer to the pot and something to hold a windscreen at the right height.
Stove Base by Pinnah, on Flickr
When these are combined (more details in the Flickr photo set), they produce a drop in boil time of 30 seconds compared to the (Supercharged) Trangia Mini + Windscreen combo; from 5:30 to 5:00. But in use, it's just way too much hassle for me to deal with.
First of all, assembling everything is just too much hassle. Setting up the Supercharged Mini is just plain out easier.
Supercharged Trangia Mini Base by Pinnah, on Flickr
Second, with the Trangia inside of the Emberlit, it is a pain in the neck to light the Trangia and worse, to get the snuff/simmer ring on the burner to put it out. You're just as likely to drop the simmer ring all the way to the bottom of the Emberlit.
Trangia in Emberlit by Pinnah, on Flickr
Third, if I'm going to carry the Trangia burner it's just as easy to carry the Supercharged Mini base than all of the "fiddly bits" involved in getting the Trangia to work in the Emberlit.
Nested Ring for Packing by Pinnah, on Flickr
Of course, you could just shove the Trangia into the Emberlit but the burn time is so horrible and worse in wind. So, I just end up carrying both the Emberlit and the full Supercharged Mini kit.
Hope this helps somebody out there.
