For what we do the strips aren't accurate enough, so we normally use a digital meter. As a backup we have kits that use a reagent and a color wheel.
I did run some numbers today based on one gallon of household bleach for 3,800 gallons of water. This works out to be a dose of around 16 mg/L (aka parts per million). So, to give you an idea of what this means...Dose minus demand equals residual. Demand is the amount of chlorine it takes to kill all the bugs and end up with no chlorine residual left over. However, you always want to be left with a residual to prevent further contamination, so your dose must always be greater than your demand. In a potable water system a residual of around 2.0 mg/L is ideal (opinions vary). So, if your dose is 5.5 mg/L, and your demand is 3.5 mg/L your residual will be 2.0 mg/L. Clear as mud?
Basically a dose of 16 mg/L will probably be like taking a bazooka to a knife fight. However, without knowing the quality of the source water, it's probably better to be safe than sorry. For short term I wouldn't have a problem with it, but long term I'd be concerned about drinking any water dosed to this level without knowing the residual.
Overall a good site with good information. Two issues I do want to mentions... First, the article states that bleach purifies water, which is certainly does not (doesn't sterilize it either). Bleach is a disinfectant only. There are bugs, like crypto, that are resistant to chlorine. Bleach will not remove suspended or dissolved solids. Second, smelling bleach in water is not necessarily a good indicator of successful disinfection. Objectionable taste and odor (sometimes bleach-like, according to my nose) can also occur as chlorine is simply reacting with organic matter.
Told you I was a water geek.
