emerson a-100 questions
is the blade a flat grind or v grind or chisel grind? i just wante to know because i dislike chisel grinds thanks
its ground on both sides but the actual edge is chisel
I just picked up a mini today and I love it
if you look at the picture of joes knife you will see part of the blade is coated. that part is flat. the shiny part of the blade tapers down to the edge. the other side is the same. this is called a scandi grind edge. it doesnt have a secondary bevel. most people like this type of edge since you can lay the blade flat on a stone to sharpen it. the only drawback is if you chip the edge. you have to remove a lot of metal to sharpen the blade past the chip.
the A100 isnt a ZBG, i dont think any productions are.
the ZBG has only 2 angles vs the usual 3.
