I actually zero in on and use smaller blades between 3" and 2.25" most of the time anyway, but most of them are such small scale that its very hard to find a 'serious' blade in that length. Taken in this light the blade on the CQC14 is no bigger cutting wise as far as the edge is concerned than a common Buck Squire but compare that to the comfort of really making hard cuts requiring some muscle and real leaning into it to force it down and through like you need to with hemp rope, or thicker rubber tubing and its hard to believe the blades are in the same category legally speaking.
There are of course other issues to consider about owning a shorter blade. Typically speaking any weight put on the tip of a longer blade longer handle translates into more pressure at the pivot than a smaller blade smaller handle knife. In other words 100 pounds of weight on the lanyard end of a Spyderco Military is a lot more at the pivot and lock contact than 100 pounds of weight on this 14 would be so in that regard the 14 in all liklihood even with the longer handle and it may actually have a higher strength and hold more weight on the tail which could also translate into higher reliability which in a liner lock is important. I don't think this shorter blade longer handle concept is going away folks. More and more we'll be seeing this I think, and especially in major urban areas.
One thing I have learned with Emerson knives in particular though is that they don't usually come new in the box very refined or broken in at all. For me when they have this has been rare. Most are somewhat gritty as all four of my own 14s have been that required some serious use and breaking in to get right, and also my biggest concern is that the locks don't engage fully on most new EKI knives. My EKI folders are no exception. My oldest 14 is from right after they came out bought the day after actually, and its just now starting to see the lock move in far enough to actually make me start to feel like it can be trusted. Well, as much trust as I will ever put in a liner lock I mean. It will never be in the same league as my frame and axis locks but hey, they can and do work if you know what to look for. You just can't be asleep at the wheel too much with a liner locking folder so generally I'm very careful with them, especially in certain cutting and high tip stress uses.
STR
