Emerson mod for a thumb-studded folder.
I was thinking earlier, if you have the spydie hole, you get the ziptie mod. But, what can you do for a knife with just studs?I'm still coming up with ideas, post here any ideas you have. :)
Someone on here posted a pic of a knife they had done this too using wire (maybe a large paperclip) that wrapped around the thumbstuds and then looped up to make the opener, then back down on the other thumbstud. I can't remember the name at this moment, but will post if I do.
Sounds good! :)
I usually remove the thumb stud and cut into the hole to make a wave hook
It can be done using small wave made as a separate part and attached to a blade by a thumbstud. I've found some old photo of my 710 modded with in that manner.
It is called surf-up.
That's actually the knife I was looking to do it to. I don't know though, kind of ruins the shape for me. I may just keep it as it comes :P
If you won't like it, it could always be removed, it's not a permanent modification ;) And it works really well, I assure you :)
