emerson/strider mod
i was wondering if this can be done. i have a thing for striders and emersons i just got q cqc14 and was wondering who could do a one piece g10 side like the scale and the back spacer is all on piece. along with a ti fame lock? thanks alot :D:D
Based on my measurements of the CQC14 I have here you'll need a .310 thick block of G10 to pull that off.
I am not sure where to get that. I've never bought anything thicker than .160 but if anyone has it Halpern Titanium will and if you are lucky they'll have some in stock that has the Strider texturing on the one side for some grip improvement.
Then of course once you get the block you need to find someone that can mill or cut the pattern and form the once piece block you want of the handle scale and the spacer all in one. I don't have the means to do it. You might check with Ferrrk on the greener forums but I've never seen anything from him that did that either. Strider has CNC waterjet laser cutters and machines programmed to cut that out for them. Even if you find someone that has the machine I doubt its a simple matter or worth the time to reprogram it to make a one time cut for someone. Thats my guess anyway.
STR
