Engraved Fighter with Silver wire handle inlay. This blade is 7 1/4 long and overall length is 12. Quite a bit bigger than an average hunter but about right for a fighter. The steel is 154CM stainless. The colors you see on the blade are only skin deep are from heat treating. The colors range from smokey gray to a golden irridescent rainbow. Normally this is ground off but I liked how it looked and left it. This colorization is only on the surface and will eventually wear off like an annodized or a hot blued steel knife would wear but it should last quite awhile. It doesnt harm the blade, in fact it will provide some extra rust resistance. The engraving starts at the rear spine, flows up and spills over on to both bolsters and then returns to the spine to spill over on to the front of the blade to slide around the makers mark. This required engraving the blade soft, heat treating it and then lining it all up after the bolsters were attached and finishing the engraving. It was a bit complicated - at least for me. I am new to engraving so its not as fancy as some but I also didnt want to do a traditional engraving either. Its a fairly agressive vine and thorn with a little poisen ivy thrown in to boot. The handles are curly maple and inlayed with silver wire. The 416ss bolster has been dove tailed. The sheath is custom built and fitted to this knife with concho accent for the loop wrap around. The sheath has been cut away to show the engraving on the reverse bolster. The swedge has not been sharpened but can be easily enough.
There were several new things for me in this knife that I hope came out OK. I had fun making this one as it was probably the most challenging knife I've made.
Several more pictures are here > http://www.mickleyknives.com/html/engraved_fighter.html
If you are curious, you can see several pictures of how this knife was made starting here> http://www.mickleyknives.com/html/page_20.html
As always, any opinions are always appreciated -good, bad or otherwise. Thanks for looking.
