Engraving viking
Fallkniven (engraving).
Friends of the forum, desire to show this engraving that have finished. Inlays of gold, copper and silver.
A greeting
Montejano
wow, that's just beautiful!
Think you will have got one hell of a happy customer with that!:thumbup:
How long did it take you to make this highly detailed piece of art?
I assume his hair and face were the most difficult part?
...I just notice something.:eek:
In the last two photo's there is a small line or something under the engraving that isn't present at the other pictures.
I hope it isn't a scratch or something? Or is it just your signature/dust.?
I'm in awe... :eek:
That is simply wonderful.
Question , when you inlay the gold , copper , etc , how do you make it stick to the steel ?
I mean , the inlay will never come off ?
Very nice job Sir. :)
Thank you all for participation and by the words.
Try to answer your questions.
I am master engraver to "strong water" with traditional technique of the nineteenth century. I am the only master engraver in Spain, which maintains a technique inherited from TOLEDO (Spain), and that I have improved independently for 24 years.
This engraving Viking, it is not done to "strong water" and is made with the technique of "drypoint" (special punch). It is a technique similar to Burin, but the cut on the metal occurs rebaba this rebaba may be left for work of printing (intaglio) or can be eliminated.
I hope to make successive prints of this type and combining the technique of "heavy water" with the technique of "drypoint.
Regarding his consultations say:
That detailed and drawn shade of Viking is achieved by increasing (or binocular microscope) and with a punch very thin, about 0.2 mm in diameter, this spike is afila to increase to achieve a very thin edge, it manages to make a cut or stroke similar to Burin finest.
The print is on one side only.
The embedding of noble metals on other metals, is called "damasquinado." To embed a metal over another metal, there are numerous techniques or processes. The most commonly used is by means of "milano queue." There will always be a cut on the metal and then they cut side, so that the bottom is wider and the top is closer. Thus when striking metal (gold, copper, silver, etc.) with a hammer and a botador ago that the gold embed within the slot and no longer can leave. It is embedded forever gold in the steel.
Gracias a todos por la participación y por las palabras .
Intentaré responder a sus preguntas .
Yo soy maestro grabador al “ agua fuerte “ con técnica tradicional del siglo XIX . Soy el único maestro grabador en España , que mantiene una técnica heredada de TOLEDO ( España ) y que he mejorado de manera autodidacta durante 24 años .
Este grabado vikingo , no está realizado al “ agua fuerte “ y está realizado con la técnica de “ punta seca “ ( punzón especial ) . Es una técnica similar al buril , pero al cortar sobre el metal se produce una rebaba , esta rebaba se puede dejar para trabajos de impresión en papel ( calcografía ) o se puede eliminar .
Espero hacer sucesivos grabados de este tipo y combinar la técnica del “ agua fuerte “ con la técnica de “ punta seca “ .
Referente a sus consultas diré :
Que el detalle del sombreado y dibujado del vikingo se consigue por aumento ( binoculares o microscopio ) y con un punzón muy fino , alrededor de 0,2 mm de diámetro , Este punzón se afila con aumento para conseguir una punta extremadamente fina , que consigue realizar un corte o trazo similar al buril más fino .
El grabado es en una sola cara .
La incrustación de metales nobles sobre otros metales , se denomina “ damasquinado “ . para incrustar un metal sobre otro metal , existen numerosas técnicas o procesos . La más utilizada es por medio de “ cola de milano “ . Se realiza un corte sobre el metal y después se hacen cortes laterales , para que la parte inferior sea más ancha y la parte superior sea más estrecha . De esta manera al golpear el metal ( oro , cobre , plata , etc ...) con un martillo y un botador , hace que el oro se incruste dentro de la ranura y ya no se pueda salir . Queda incrustado para siempre el oro en el acero .
Absolutely beautiful!
I did not know anybody still did such detailed work by hand.
An awesome work of art!
Thank you for your reply and explanation Montejano. :)
Now I understand how the noble metals adhere to the steel.
fghjcvbnm <....You see those letters??Those are from my jaw hitting the keyboard.That is simply stunning work.Exelent job.
WOW! Fantastic Job! That knife is unbelievably gorgeous! Do you have pictures of other knives you've done to share with us?
Thanks to friends for participation.
Friend grey.
I show muches of the works that I accomplish at this forum, as also I show them at another important forums. You can look my after and discovering some of my works.
A greeting
Montejano
