How do the Enzo Necker 70 Full Flat Grind 12c27 and ESEE Izula compare?
Which is more comfortable to use without scales?
Are the spines of both squared for striking a ferro rod?
Do the kydex/plastic sheaths of both retain tightly for neck carry?
Thanks!
I have both a Enzo Necker (with my scales and kydex) and my partner have a Izula (with factory scales and sheath).
The Enzo Necker with FFG is much thinner behind the edge then the Izula, much more of a cutter IMO, but if the intended use was more poking/prying the Izula is probably better.
Without scales I think the Izula wins out, the Enzo is kind of sharp around all edges as far as I can remember. Then again, it wouldn't be too hard to bevel the edges some. Striking a ferro rod shouldn't be a problem with the Enzo, I haven't tried it with the Izula, but the painted blade might make it harder.
About the sheaths I can't say anything about the factory sheath for the Necker as I haven't tried it, but I suspect is needs scales to hold onto the knife, don't think it'll work with just a bare blade. But if you have a heat gun you can always modify it as you want it.
Izula definetly holds on to the knife, almost to the point that it's hard to extract, I think this sheath works equally good with a bare blade.
Another thing, if you're serious about neck carry, don't put G10 handles on it, it raises the weight considerably. If Enzo had the Necker with a different blade steel, I would probably get another one and put thin scales from a light material (maybe carbon fiber) on it.
