Enzo PK70 Scandi grind slipjoint folder
I received my much-anticipated PK70 folder from brisa.fi last week. It's a knife made in Finland (I think) and available from www.brisa.fi (with whom I have no affiliation)
I've been keen to try this knife as I liked Enzo's locking folder (the unfortunately named "Birk") and I have wanted a UK legal edc folder (sub 3" blade, non-locking) with a scandi grind for ages.
The knife is available with full flat grind blades, too. All are CPM-S30V (unlike the Birk, which also comes in D2). There are a variety of options for scales and bolsters. I chose the cheapest option -Scandi grind, no bolster, CF scales. Unlike the Birk, unbolstered knives have full width scales.
From the website it appears the bolstered models do not have a pocket clip but this is only an observation.
Here are stats for the PK70 range, lifted from the Brisa website:
Length: 160/92 mm
Weight: 80 g
Blade length: 70 mm
Blade thickness: 2.5 mm
Steel: CPM S30 V
Grind: Scandi (Sc)or Flat (F)
Finish: Satin
Lock: No lock, slipjoint
Frame : Stainless 1.2 mm
Clip: Stainless
Washers: Bronze
Screws: Torx 6 . Pivot Torx 8
Bolster (B):Titanium 6-4
Scales: Interchangeable
Brisa sell the knife without scales and a drill guide/template is also available so DIY scales will be easy. Cue orange G10 from some of our tangerine addicts.
So what is it like?
The short answer is, it's gorgeous.
I love its sleek, purposeful lines- very "scandinavian". The nail nick adds a charming scowl. These side-lit pics make the grind lines on the flats and bevels look more coarse than they appear in reality. I like this style of CF finish- very tactile (not too tactical) and pleasing to the eye:
Since its main competitor (in the UK) is the excellent Spyderco UKPK I have done some comparison shots:
It doesn't look so tidy when closed, but still a compact package:
That nail nick is positioned much nearer the tip than most designs. This makes it easier to open as you have a longer lever to overcome spring pressure. This is just as well since there is very little blade showing to grip when closed. One-hand opening is NOT a realistic option without modification (this will appease our Danish friends):
It's a little thicker than the UKPK. The polished, stainless pocket clip (not repositionable) adds another 30% thickness:
Despite the lack of choil, I find I can safely initiate blade closure, without moving my fingers from a full grip position, using my thumb on the spine. The sharpened portion of the edge does not contact my finger unless I am gripping the handle unusually far from the pivot. There is a distinct halfway detente position but care should still be taken when closing.
In hand shots (it's quite dinky but not annoyingly so.)
Fit and finish are superb. There are almost no perceptible gaps and the blade is perfectly centered. There is no play in either plane once "locked-up". The grinds are symmetrical.
The pocket clip is slightly clumsy-looking but it has plenty of clearance for thick pocket edges (the Cactus trousers pictured are very chunky). The knife carries tip-up and this cannot be changed (without drilling and tapping new holes.) The clip design allows deep and discreet carry:
The Birk and UKPK ride higher (although I haven't pushed the Birk as low as it should be so it isn't an accurate representation, sorry!)
In use:: I've polished the bevel (a bit) and carved a spoon from a blank as a test of comfort and function as a basic pocket whittler (ordinarily, much of the work would have been done by axe/saw if I was not doing this as a knife test):
Halfway -no blisters yet!
As much as I'm going to do before letting it dry a bit, will still need a lot of thinning and shaping:
There are a few hotspots but as I write this, no blisters have appeared:
The spoon is far from finished but the knife has been put through several hours of use.
My intended role for this knife was as a UK-legal whittler and it has excelled in this task. The blade is still plenty sharp enough for more carving. I haven't closely inspected the edge yet but with the naked eye there isn't any gross chipping or rolling. I'll do some macro shots to check this.
What do I think after this short period of ownership:
Pros:
The fit and finish of this example are exemplary
Good quality materials (assuming they are the same as my Birk in CF and S30V)
Scandi or Flat grind options
UK and most of Europe legal EDC
Deep pocket carry
Looks good when open
Pocketable
Pleasant CF finish, nicely chamfered edges
"Clever" nail nick
Price (a matter of opinion)
Easily Customisable with aftermarket Brisa kits
Cons:
Clip a bit clunky-looking (might be better in satin finish?)
Only one clip position (but this avoids untidy spare holes)
Looks a little untidy when closed- exposed tang may snag?
Lanyard hole edges quite sharp -may fray the CF or the lanyard material?
Summary:
I've only had this knife for a short period and as we all know, there is a tendency to gush over shiny new things. However, my initial reaction is that the knife offers a great value EDC option for a very reasonable price. This model was 79 Euros on offer (but just over 90 euros to get it to my sweaty mitts.) I expect the Flat Grind version will suit most people better but for now, this knife is the answer to one of my previously unanswered knife prayers! (Spyderco Slippy in serrated H1 being another...)
Thanks to Brisa and Dennis for this new range. I have no conflict of interest/ulterior motive with respect to this product and this review, etc.
I have been interested in this knife, and really appreciate your excellent review. Thank you.
Tom
Great to see a review of a knife that would not normally be my radar.
Looks great... a little boxy but would make a nice "office" knife.
That looks like an amazing knife!
It has almost everything I like all in one package: Slip jointed, scandi-gound, deep carry clip, Emerson CQC-7 style handle shape.... Must have one!
(It actually looks very similar in shape to an Emerson CQC-7A model, one of my favorites)
Hmm , that is truly interesting.
If only they opted for something other than s30v.
Thank you for sharing , that is a cool little knife.
Tostig
Tostig
If you are ok with a locker, the Enzo Birk is very similar but is available in D2.
Yet another sign from the knife Gods that I need to try an Enzo. Or maybe it's just the very well written reviews. ;)
I'm really wanting the Birk, but I wanted to know about this knife as well!
Thanks for the nice review. I like the spoon also! I have owned the same knife for 6 months and have also enjoyed it.
I've been looking at this knife in curly birch for awhile. Thanks for the review.
