Safety first, kiddies!
Here she is, gutted. You can see the driver, module, heatsink and lens assembly. The anodizing is very nice. Top notch host. Note little details like the double o-rings on the body. The switch is a very smooth side mount reverse-clicky.
A closer look at the heatsink. The machine work is very tight, and copper is not easy to work with. You can see the twin module set screws.
Here you can see the positive contact,
A macro shot of the driver. This puppy is 9x12mm, and supplies a steady amp of current.
A (not too terrible,) macro shot of the diode in the module. And some thermal compound. With a hair stuck in it. (Eww.) Note the yellow hue of the diode window. This is because it has been anti-rflective (< I'm going to leave this typo alone to illustrate how annoying my dyslexia has been lately.) coated for blue wavelengths.
Here she is, all back together and polished up with some half-micron diamond spray. No, Mister toothpick, I expect you to DIE!!
BWAHAHAHA!
Aftermath. . .
"I'm afraid I can't do that, Dave."
