- Sep 27, 2007
Okay, yes I know I should have posted this earlier today before I went and mixed up the epoxy, but.........you know how it goes sometimes
I've been using slow cure epoxy on all of my handles and have had pretty good success, but I've had an issue here and there where slabs and liners came apart. Could have been from not cleaning or prepping well enough, but sometimes I wonder if it's from squeezing out too much epoxy and not having enough left between for a bond.
I just now glued up some jigged bone slabs to some G-10 liners and I started thinking that maybe I should just press them together lightly and leave them on the bench to cure for ten minutes or so before I clamp them down with spring clamps. I thought it might let the epoxy harden up just a bit before the pressure is applied and keep more from oozing out the sides.
I am using West Systems G-Flex that cures in 45 minutes and I always rough up my surfaces then clean thoroughly with rubbing alcohol. I also always drill in some dimples on the back side of the handle material for epoxy to collect in and make a thicker bond.
What do you guys think? Clamp immediately or let it set for a few minutes?
Thanks, and by the way......quick answers would be appreciated since it's already been five minutes since I glued them together!!
