My question is about the best way to use epoxy with my handle scales. I use two-part epoxy, I get it as close to a 1:1 mixture as possible, and I mix it thoroughly. I coat the scales completely with the epoxy and clamp the scales to the tang. I always have epoxy oozing out the sides, expecting that I've fully secured the scales. (And I always have another mechanical means of holding the scales, like corby bolts, not just epoxy.) Several of my knives have gaps between the scales and tang, even though there was a lot of epoxy in there. When I clamp the scales, I make them as tight as possible.
Should I clamp the scales on really tight? Or is that forcing too much epoxy out, leaving the gaps when the epoxy finally cures? I'd appreciate any thoughts on this!
