bladefixation2
- Mar 28, 2004
Santa brought me an Extrema Ratio fulcrum II D (lockback folder)
Initially I was more than pleased with its build quality but after a couple of weeks of playing with it Ive noticed there is vertical blade play when its open. This is fairly significant probably in the region of 1/2mm in the vertical direction if you hold the spine and the handle and move them in opposite directions. Not something I had expected from such an expensive knife.
The only other lockback I own is a spyderco endura PE FRN, I have checked and there is no such play on this, not withstanding the fact it cost only about 1/4 as much as the fulcrum!!
I've taken the knife apart and checked, there is no obstruction in the lock mechanism and the silicone washers are both in place, it seems to be that the pivot doesnt perfectly fit the hole in the blade and the peg on the lockback mechanism doesnt perfectly fit the associated cutout in the blade. I checked the pivot tightness, its as tight as it will go without being so tight you cant open the knife! The knife hasnt been through any hard use at all since Ive had it.
Has anyone else experienced this problem with a quality lockback knife before? I dont know if I should return the knife or if its just how it is...
