I absolutely love my new Izula but, I thought the coating was creating too much drag during food prep. I also have been seriously wanting to strip the black finish since making the Brazilian Cherry scales for it last week. So...many Youtube vids, threads on the topic here...I gave it a try.
I used aircraft stripper to remove the coating. That was surprisingly easy, 30 minutes of set time after spraying, a plastic knife and brass brush took all the coating off. Earlier this week, I etched the ant emblem and the logos with radio shack circuit board etching solution...3 one hour sessions per side, should have done 5 probably as they are visible but not as deep as I would like.
I wet sanded the knife with 600 grit paper and then cleaned with alcohol. I used walnut husk juice for the base patina. I squeezed blackened walnut husk (wearing gloves), dripping the juice over the knife, and hung the knife vertically. I did two coating of the walnut juice, letting it dry completely between coats.
After the second coat dried, I wiped the knife down with an oily rag and lightly scrubbed it with 000 steel wool to even out the finish and smooth. I then cleaned the knife with alcohol.
The next step was striping the blade with French's Mustard, roughly 30 minutes per side. after wiping the blade down with oil, I put the scales back on. I sharpened using a Work Sharp Field Sharpener...( I love this sharpener because I am the worlds worst sharpener. before I bought this tool, anything I have ever tried to sharpen was completely child safe when I was finished..about butter knife sharp.)
Critiques? Suggestions? Im trying to learn and am having a great time!
[/IMG]
