For around-the-farm work I'd go with the Lite Machete hands down. It's an actual "proper machete" rather than a pseudo-machete/chopper hybrid. The longer thinner blade will be much more pleasant for farm work. Both are great tools but the Lite is much more agriculture-friendly.
Have you thought about trying a Tramontina first? They are in the best buy category. You can get one for less than $8-$9 pretty much anywhere. The handles, while not Micarta, are excellent and easily tweaked to fit your hand if needed since they're wood. One will need a good sharpening upon arrival, but that's easy enough with only a file. I'd give one a try. They're so good and cheap, you'll probably want one for the truck, one for the tractor, one for the barn, etc.....![]()
Interesting how some of the most inexpensive cutting tools are often the most usefull, like a machete or Mora knife.
I think the Golok very heavy and thick. But is good for hard trees. I prefer the ESEE. But it depends on the type of vegetation that you want to cut where you live...
The newer ones have a stronger distal taper to them, for the record. Makes them much faster in the hand than earlier models but still with plenty of "oomph" while chopping.![]()
I know they went from "distal taper" to "no distal taper" on that one
What do you guys think of this Tramontina? I could put a patina on it since it's carbon steel. It seems every where is sold out of ESEE Lite machetes. What's a good alternative to the Lite? I want one of the same quality and bladeshape. Thanks!
