- Mar 6, 2005
Two things I'm having trouble finding information on are quenching mediums and etching. I'm a registered user of hydrochloric acid, but I've gone to lengths of letting steels soak in the stuff for over a day after scratching away the "tar" material with barely distinguishable results. I've tried consulting professors of material's processing from the university I'm attending and they haven't been able to tell me much. I think one of them said that hydrochloric acid might work better with aluminum rather than steel, but that doesn't help me much with the steel issue. Is ferric chloride the answer? As for quenching mediums, I already understand that the rate of cooling determines grain growth which is responsible for where the metal turns out on the spectrum from hard and brittle to soft and flexible. The viscosity of the fluid would control the cooling rate where oil could produce springs and water could produce nails. That would be the physics of it. My question is rather about the chemistry of it. Could I get various finishes and results through different mediums? Vinegar, bleach, and ammonia all basically have the viscosity of water, but do they produce different colorations and shines? Other mediums I'm trying to find out about are milk, dish detergent, isopropyl alcohol, and cornsyrup. I'd think that when high levels of heat would be introduced to corn syrup it'd carmelize and the remaining carbon would act as interstitial molecules strengthening the surface, but I haven't read anything about common uses of high-fructose mediums and wonder if there's a reason for that. I'd very much appreciate any help or direction anyone could give me with this.
