Rob! said:
The etchomatic also has AC/DC capability - just uses a small diode on the ground clip. It works great and in this case, the low power is almost an advantage because it goes slow enough that you don't go too far too fast or burn out your stencil.
Rob!
Yes, I have a marking methods and I only use it on half power. Anything higher gives fuzzy etches and burns the stencils out prematurely.
Hell, it it works and is affordable, go for it. The biggest reason the lower priced units don't give really good results is because of hand pads and cheap, or the wrong material stencils.
Get the Marking Methods deep etch hand pads and felt pads and rubber keepers to go with them and the biggest part of the problem is solved. Getting the Marking Methods heavy duty green stencils will complete the job. You might have to argue with Marking Methods to get those stencils, so the best bet is to get the equivalent stencil material from this place, the one that started the metal etching business in the first place. They have deep etch hand pads and the felt covers for them too.
http://www.lectroetch.com/
The thing is, buying all the extra stuff to make one perform better brings you close to the price of a more expensive unit to begin with.
The other part of the problem is using that had pad correctly.
Saturate it in the "correct" solution for your steel type, and blot the handpad on a folded paper towel until it barely makes a damp mark, then it's ready to use.
With everything ready to go, place the handpad on the stencil without too much pressure and hold for the count of three, lift for a couple of seconds and repeat. Do that about 15-20 times. If you see wetness under the stencil, dab the handpiece on the paper towel a couple more times), then switch to AC and repeat the same process about 10-12 times to redeposit black oxide in the etch.
Take the blade to the sink and peel the stencil off(I hold mine on with tape on the sides) use the cleaning solution(you do have that don't you?
) on blade and stencil. If your blade is mirror polished, lightly buff that area to get rid of any hazing and fuzziness. If it's handrubbed, then just make a few passes with your last grit used, using WD 40 as a lube and you can watch it get sharp detail as you rub.
If some of the black should come out, no worries, just clean the area of the etch and use a black sharpie permanent marker to rub that area. Let it dry and using a piece of sharpened hardwood or micarta(Just a chisel type edge on a small piece of scrap) scrape the excess off. It shouldn't harm the finish of the blade if you're careful.
Edited to add: Mike Fitzgerald(Fitzo) did an in depth study of all the available etching units in a detailed thread at the place that used to be called CKD.
But they changed the name and in their infinite wisdom made all the saved links inoperable so I can't provide it for you here.
It was originally done in the Supply forum over there. Maybe Mike has a link to the new location?
