etch-o-matic ?
I'll admit to having and using one. It does an O.K. job of marking my blades, both stainless and straight carbon steel. It doesn't really have enough guts to make a very deep etch. It's better than nothing, but if your buying new, I'd think of a Personalizer or something a step up the ladder. Or make your own set up as a few of the fellas around here and CKD have done. I believe there is a tutorial on making an etcher around here somewhere, just do a search and it should show up. Bob Warner on CKD has the info on his web site as well.
Clint
www.chisanknives.com
Thanks, not having any experience with etchers you wonder what the difference is bewteen the $25.00 etch-o-matic, the homemade, the $100 unit and the $150 unit.
Is it the power? or is the real difference in the stencils?
A good stencil can make or break an etch, as far as quality and crispness of the lines, which is fairly important on such a small "sign." You may spend $50 on a good quality stencil, but it is worth the money.
I believe that the etch-o-matic just doesn't have the power to really burn the etch as deep as the upper models do. A few of my buddies have Personalizers, and you can really see a difference between an etch done with one of their rigs and one done with mine. Now that I'm thinking of it, I should probably bite the bullet and upgrade!
Clint
I use an etch-o-matic. My "sign" is just my last name (REJMAN) in capital letters. I make the stencil using an old dot matrix printer, removing the ink ribbon so that the keys strike the stencil sheet. This will do me fine for a long time! I'll get a metal cutting band saw or a Drill Doctor before I get a better logo gizmo.
