- May 30, 2006
I've been experimenting over the past couple weeks to try to get a better etch in damasteel, and I can't get a high-contrast pattern. I'm using Muriatic Acid from Lowes as an etchant. The pattern comes out kind of gray-ish. I've tried anywhere from 400 grit on up to 1000, but still haven't found a very contrasting pattern.
I've tried etching anywhere from 5-20 minutes. The longer times etch the blade more deeply, but still the same gray color.
I've also tried "setting" the pattern in hot water after the etch. A little oil helps, too, but I'm more interested in making the pattern stand out.
The pattern is darkest down on the tang end where it's only finished about 60-120 grit.
Is there something I'm missing, or is this just as good as it gets? The only other damasteel blades I've seen have been in photos online, so it's hard to tell.
