That’s what I have done and I think that’s what the manufacture recommends.Muriatic then come back with ferric to color it.
Does it have to be hot?Muriatic acid outside
I used the Todd begg YouTube video
I followed the video so I did heat it up..... I don’t know how it will work if you don’t heat it upDoes it have to be hot?
Yeah I do use ferrc. I've found using a fresh batch works the best. I 've used this on other stainless dammys too with good results. I warm it in the sun if I can:
Damasteel:
Thx for the update. Good to know. I guess I’ll dump my muriatic acid.![]()
It worked. It was my old vinegar ferric mix. Thanks for the info. The second etch was deep enough that I can feel the topography.
The first etch was around 30 minutes and the second was around 45. The acid was old but hasn't been used much. I put it on a heater vent so it was warm but not anywhere near hot. The second went pretty deep.Thx for the update. Good to know. I guess I’ll dump my muriatic acid.
I got it done with being stupid .Storm ... FWIW ... I put my pvc pipe with ferric in it in a Home Depot bucket (using zip ties around it to keep it vertical). When I went to etch, I just filled the bucket up with hot water from the faucet. Did a good job of heating the ferric up. Temperature is really important to the speed of any chemical reaction....
Its pretty cool what you can do by just trying the thing that you know doesn't work. ThankfullyFunny how things don't make since until the light goes on. I had a suminagashi san-mai blade that I was etching one February. The FC tank is out in the open smithy. I etched for almost an hour and only had a pi$$ poor etch. I cleaned it several times, stirred the tank, topped it up with fresh FC stock, and was about to dump it and mix some new FC when it suddenly dawned on me that it was 30 degrees outside. I waited a few days until it was in the 50's (temperatures changes fast here), and the blade etched just fine.
A good rule of thumb for the most part, but I study some reactions with a negative temperature dependence...Lol. Arrhenius Stacy ... Arrhenius.![]()
Really? not common .... are you able to reveal the reactions? (I am both chemist and Chem. E.). I could see Le Chatelier's principle leading to that in a really, really exothermic reaction --- but that would have to overcome the increased system energy swamping the activation energy lower limit....... ????? (sorry folks for the nerdy ramblings ..... just curious......)??A good rule of thumb for the most part, but I study some reactions with a negative temperature dependence...
Generally a signature of barrierless gas phase reactions where capture limits the rate.Really? not common .... are you able to reveal the reactions? (I am both chemist and Chem. E.). I could see Le Chatelier's principle leading to that in a really, really exothermic reaction --- but that would have to overcome the increased system energy swamping the activation energy lower limit....... ????? (sorry folks for the nerdy ramblings ..... just curious......)??
