- Jul 8, 2001
I sanded this blade to a mirror finish to grit 1500 sandpaper, then wiped down with acetone and washed with soap and water, then put it in a jar of ferric chloride mixed 1 part acid to 3 parts water, for 30 seconds,when it came out and I cleaned it up it was showing a lot of scale pattern in the riccasso area, so I sanded again starting with 320 and worked to 1500 and dipped it again, the blade looks fine but I can't get rid of the scale look in the riccasso area, What do I need to do to eliminate this scale look? By the way the steel is 52100 and its 3x quenched, also I sanded a great deal off after heat treat with belt sander to get to this point, the blade looked great with a mirror finish no scale or scratches showing anywhere.
Thanks for any help
Bill
Thanks for any help
Bill
