- May 13, 2012
UPDATE: Final pics added. Post #8
After getting my BK7 stripped and set up just the way I want it, I decided it's finally time to strip the BK9. I wanted to do something a little extra on this one though...
So I'm doing an etching on both sides of the blade. On the right side, we have BECKERHEAD #249. On the right side I will add UNCLE MALICE.
I couldn't figure out a good way to do the stenciling/etching... so my method may be pretty weird to you guys. I printed out a label with the text... and then freehand drew the characters onto the blade with pencil. Once I had the outlines all done, I used the sharp tip on my soldering iron to cut out the finish. The heat melted it away and I just sorta scraped it away. There are probably better ways... but I actually like the way this is turning out. Once I got through the letter blocks with the soldering iron... now i'm just doing sessions with the PCB etchant solution to get it down into the blade. I started yesterday, and what you see in the picture is the result of about 2 hours of etching yesterday and about 3 hours today. I may go a little deeper... still trying to decide.
I'll follow up with the next side as I progress...
