- Sep 14, 2010
Anybody got a good setup for a deep etch? Knifedog Etch or Personalizer Plus?
I use a home-made one from Chris Crawford's plans, works great. Nice deep etch...
Is this as easy as it looks in the plans? I could put this together for about a 1/4 of the cost of a Personalizer Plus!
Is the Etch-O-Matic any good?
I came across a fairly inexpensive power supply, only 28.77! Wouldn't this do the same thing as an etcher set on DC?
http://www.bgmicro.com/PS1303U.aspx
YES! Seriously, it is very simple to do if you have all the parts/tools in front of you like the directions suggest. I soldered and used heat-shrink tubing but otherwise stayed pretty much right in line with the plans.
Stacy mentioned in a thread that you should repeatedly turn it on and off with a push button, instead of on-several seconds-off. I started doing this and have had much better success. I turn it on/off probably 20 times over the period of 3-4 seconds and get much sharper etches with less bleeding.
Thanks again, Stacy.
http://www.bladeforums.com/forums/showthread.php/609064-Looking-for-electro-etch-plans
http://www.bladeforums.com/forums/showthread.php/756801-Making-and-electro-etcher
http://www.knives.mlogiudice.com/knifeshop/etcher/index.shtml
http://www.knives.mlogiudice.com/knifeshop/etcher/electro-etcher_circuit.pdf
