Steve,
I am using a variable DC voltage supply set on 5.5 volts, I measured 6 amps. I etch between 10 and 15 minutes. I get a deep etch and still have good resolution on the letters. If I try to etch on ten volts(the amperage also goes up) the resit will start to burn off. If you have any ideals on how the voltage and the amperage determine the quaility of the etching I would like to hear more about it. Specifically on how I could contol(lower) the amperage when I turn up the voltage.
Sharpsteel,
KTFR is a photoresist or UV (black light) sensative solution that is applied like paint. You have to let it dry and bake it for 20 minutes at 176 degrees F. Let the steel cool and lay the transparency on top of the photoresist. Put this under a black light for 20 minutes to expose the photoresist. Develope the exposed photoresist for 2 minutes and wash off with warm water. Post bake for 10 minutes at 248 degees F. Now you can etch. After etching clean off the resist with the developer.
KYFR is available from P.C.&E. phone # 610-296-8585.
