I've always wanted a straight razor but nice ones are $100-$300 and up. Since I consider myself a novice knife builder I decided to give it a try but I'm a little confused on a couple points.
I ordered the blade from alabama damascus, it'll be here soon. The blade is carbon damascus and will need drying between uses, so I was thinking of putting extra space between the blade and handles for airing out (plus the extra thickness is easier to grip). Should I build a stand that holds it folded out for it to air out or will toweling it off after use be enough?
The handle material will probably be a stabilized black ash, or some other stabilized wood. For fun I plan to inlay some abalone and MOP.
The plan is use titanium sheet as liners, or nickel/silver. I'm not sure how nickel/silver would respond to many years of contact with water. Will N/S react to water? Which liner is a better choice, or do I even need one (some razors I've seen have none)? If I use titanium, do I have to do anything to make it water resistant or does the titanium oxide form from air exposure on it's own?
As far as the pivot, I'll measure when I receive the blade and order from TKS, and I'll use the Nylotron washers. Then the one pin at the other end of the handle is easy enough.
Something I'm lost on is how does the blade stop/sit inside the protection of the handle when not in use. Or does it just swing about freely 360 degrees? Do I put a small pin in as a stop or carve the handle out to have a small bumper?
