If it is perfect as it is, why reprofile? Seems drastic. And it will affect resale. Just something to keep in mind. Unless you are really good at it, if you really want it done, have it done professionally. Practice on cheap knives. Just my 2 cents.
Perhaps you're right. The knife came to me (used) fairly dull, and I'm use to reprofiling every knife I get as I find that manufacturers err on the side of edge durability, which doesn't suit my needs. The only knife that I can think of, off hand, that was pretty good was my modest little Cold Steel mini tuff lite, and even then I reprofiled it, since its purpose is for wood carving.
Just by feel (which isn't the best way to gauge an edge, I know) it seems to be decently thin behind the edge, but the grind look to be obtuse.
The biggest problem, and it IS a problem, is that the edge grind is absolutely 100% perfect. I've never seen that before, and I'd like to keep it that way, but I know that that is unrealistic. I'm not even sure that CRK would keep it right if I sent it in.
My options are my edge pro (knockoff) which does an admirable job, but there can easily be variations in the grind width if you're not in the zone 100%, and the small portion of flat side area on the Sebbie only compounds the problem.
That leaves freehand and stropping.
I'd say that I've got my stropping technique down pretty well, and it's actually helped since the edge isn't really dull, just dull to me
Freehand though no way, not at my current skill level. I can put a decent edge on a cheap knife, but no way would I touch my good knives to a stone.
Ack... I don't know what to do.
