A Short History/summary of Knives
A knife is any cutting edge or blade, handheld or otherwise, with or without a handle. Knives were used at least two-and-a-half million years ago, as evidenced by the Oldowan tools. Originally made of rock, flint, and obsidian; knives have evolved in construction as technology has with blades being made from bronze, copper, iron, steel, ceramics, and titanium. Every culture has a unique version of the knife. A knife may be either a fixed-blade or a folding version with blade patterns and styles as varied as their makers and countries of origin. Due to its role as mankind's first tool, certain cultures have attached spiritual and religious significance to the knife.
Types of Knives:
Fixed blade knives
A fixed blade knife, sometimes called a sheath knife, does not fold or slide, and is typically stronger due to the tang, the extension of the blade into the handle, and lack of moving parts.
Folding blade knives
A folding knife connects the blade to the handle through a pivot, allowing the blade to fold into the handle. To prevent injury to the knife user through the blade accidentally closing on the user's hand, folding knives typically have a locking mechanism. Different locking mechanisms are favored by various individuals for reasons such as perceived strength (lock safety), legality, and ease of use. Popular locking mechanisms include:
Slip joint Found most commonly on traditional pocket knives, the opened blade does not lock, but is held in place by a spring device that allows the blade to fold if a certain amount of pressure is applied.
Lockback Also known as the spine lock, the lockback includes a pivoted latch affixed to a spring, and can be disengaged only by pressing the latch down to release the blade.
Liner Lock Invented by Michael Walker, uses a leaf spring-type liner within the groove of the handle that snaps into position under the blade when it is deployed. The lock is released by pushing the liner to the side, to allow the blade to return to its groove set into the handle.
Frame Lock Also known as the integral lock or monolock, this locking mechanism was invented by custom knifemaker Chris Reeve for the Sebenza as an update to the liner lock. The frame lock works in a manner similar to the liner lock but uses a partial cutout of the actual knife handle, rather than a separate liner inside the handle to hold the blade in place.
Button Lock
Axis Lock A locking mechanism exclusively licensed to the Benchmade Knife Company.
PickLock A round post on the back base of the blade locks into a hole in a spring tab in the handle. To close, manually lift (pick) the spring tab (lock) off the blade post with your fingers, or in "Italian Style Stilettos" swivel the bolster (hand guard) clockwise to lift the spring tab off the blade post.
Another prominent feature on many folding knives is the opening mechanism. Traditional pocket knives and Swiss Army Knives commonly employ the nail nick, while modern folding knives more often use a stud, hole, disk, or flipper located on the blade, all which have the benefit of allowing the user to open the knife with one hand.
Automatic or switchblade knives open using the stored energy from a spring that is released when the user presses a button or lever or other actuator built into the handle of the knife. Automatic knives are popular amongst law enforcement and military users for their ease of rapid deployment and their ability to be opened using only one hand Automatic knives are severely restricted by law in most American states.
Increasingly common are assisted opening knives which use springs to propel the blade once the user has moved it past a certain angle. These differ from automatic or switchblade knives in that the blade is not released by means of a button or catch on the handle; rather, the blade itself is the actuator. Most assisted openers use flippers as their opening mechanism. Assisted opening knives can be as fast or faster than automatic knives to deploy.
Sliding blade knives
A sliding knife is a knife which can be opened by sliding the knife blade out the front of the handle. One method of opening is where the blade exits out the front of the handle point-first and then is locked into place (an example of this is the gravity knife). Another form is a O-T-F (out-the-front) switchblade, which only requires the push of a button or spring to cause the blade to slide out of the handle, and lock into place. To retract the blade back into the handle, a release lever or button, usually the same control as to open, is pressed. A very common form of sliding knife is the sliding utility knife (commonly known as a stanley knife or boxcutter).
Gravity knives
A gravity knife is a knife that opens by the force of inertia or gravity. Similar to a switchblade, it is made with a side-folding blade or an out-the-front (OTF), or telescoping, blade. The gravity knife is different from the switchblade, which is spring-driven, in that it needs to be "flipped" out of the handle manually. Military gravity knives lock open. Some English and civilian gravity knives do not mechanically lock open but rely on a strong friction cam surface against the blade. Factory-made gravity knives have various types of buttons, triggers, and fulcrum levers, which usually are used to release the blade from both the open and the closed positions.
Butterfly Knives (aka Balisong)
A balisong, otherwise known as a butterfly knife or a Batangas knife or sometimes called Bente Nueve, is a folding pocket knife with two handles counter-rotating around the tang such that, when closed, the blade is concealed within grooves in the handles. In the hands of a trained user, the knife blade can be brought to bear quickly using one hand. Manipulations, called flipping, are performed for art or amusement.
Types of Knives:
Fixed blade knives
Button Lock
Gravity knives
