- Apr 19, 2005
As a continuation of some threads on how the different pivot or hinge pins are designed on Buck 300 series, I have mercy killed a couple of terminal knives and disected them for your viewing pleasure.
This is an end view of a Schrade made Buck. It appears the blades, center brass liner and back springs were assembled as a unit and the cap end rivet swaged before slipping them into the key hole slot and a final rivet placed through scales and back springs. This is my speculation, anyone with direct knowledge please jump on the band wagon. This photo end view is ground to split the center of the pivot pin, showing the ends of the backsprings and the ground off ends of the blades to the mid-point of the pivot hole. Brass are scale liners and center liner. Warning for anyone else trying this things will jump all apart all of a sudden.
Below is a close-up of the keyhole in the scale liner, showing how the capped pivot pin would slide in place in the narrow end.
Below is a close-up of the pristine end internal workings of the disected 303 showing the end cap pivot pin, liner and backspring.
Below is an exploded view of all the parts of the above Schrade 303. As you can see, the un-ground end is connected by the capped pivot pin. This capped pin is then slid into the scale liner keyholes and the backspring rivet had to be put through the entire knife in order to hold it together. This method of assembly must have been tricky and you would have to completely cut it apart to fix a broken blade. This is why they are not covered under warranty for repair only replacement with new model.
PS I just noticed I have the scales placed on the wrong sides of the exploded view. Note backspring rivet holes. Dang.
Below is a trick to know for certain a 300 is a Schrade, look into end of bolster and one of the rivets head that holds on the bolster should just be just peeking over the round butt end of the closed blade.
Next is a sectioned view of the Camillus version. The pivot pin is visible going through the entire bolster. Making blade replacement possible. Note how the pivot pins swell as they are pushed or swaged in place. Brasses are scale liners and center liner, two on one side to create offset so secondary blades can close in same blade well. Knife is held together with scale/backspring rivet and bolster/blade pins.
Next is the sectioned end of a post 85 Buck manufactured
303. Note here the one piece bolster and liners, also the stainless backsprings. Also visible, but a little hard to see in photo, is the pivot pin. Also through the bolster. Also changed was the backspring rivet through the scales to stainless.
Hopefully pictures are worth a thousand words.
That's all I got for now, corrections, opinions and even wild speculation welcome. Thanks to WillB for pre post evaluation.
3hunderd$'s :thumbup:
