- Jan 26, 2002
The site mentioned in this thread,
http://www.bladeforums.com/forums/showthread.php?s=&threadid=263199
which has a review of the Chiruwa AK by Singularity, also has a great illustrated article on convex edges:
"Convex Profiling and Sharpening by Hand HOW-TO"
http://outdoors.free.fr/s_article.php?id_article=66
Singularity used to post here a bit, but decided that for his technique and uses the lighter, straighter blades like goloks suited him better that khuks. He got a bit of static for that.
Too bad he doesn't post here anymore, but if you poke around that site, you'll find a lot of good information.
After reading his article, I see he's doing pretty much the same thing that I've done to a few kardas and some Scandinavian blades. Right now, I'm trying it on a 15" AK. The mousepad/sandpaper trick follows whatever profile the khuk has and gets the knife sharp. But if you want a full convex bevel, I think some serious stone-work is needed if one is working by hand.
You will dish out the stones, so be prepared for that. If the stones are hard, they just won't cut as fast. No need for spendy stones for the coarser grits. I use water on my stones.
Here's the progression of stones that I use:
*Cheap combo aluminum oxide stone (got mine from Ragnar, but I see that he has sold out of the larger size)
Coarse side
Fine side
*Blue "Oregon Stone" fine side
[This is softer than the other stone and seems to help a lot to take out the scratches from the earlier abrasives--dunno it is really a smaller grit or not. Maybe it just breaks down to a finer mud in use.--Does anybody know if these are still made and where to get them??]
*600 grit paper
[Sanding lenthwise with 600 grit paper will help you see if any deep scratches remain from coarser grits. use a piece of stiff, heavy leather for a sanding block. Go back to coarser stones if needed.]
*800 grit Japanese water stone
[Yes this will dish out, and it's not super cheap--dunno what else cuts this fast and yet doesn't leave deep scratches though--the "secret" to a smooth finish, IMO]
*600 grit paper again.
[This is very close to the water stone, you should be able to get a nice hand-rubbed finish if you haven't rushed through the abrasive sizes but it leaves more obvious fine scratches.]
Optional:
*800 grit Japanese water stone again.
*3000 grit water stone.
[Dang near polished--could go to finer paper next, or just strop the thing with green compound and use it like I do--pretty soon it will take a polish]
Two-sided 800/3000 grit waterstone are available, that's what mine is. Coarser Japanese water stones apparantly wear really fast, it's probably better to use something else like I do for the coarser grits if one is doing major reprofiling.
A couple recent threads on the shop forum have info on using water stones for profiling. (In that case the idea is to keep a crisp, sharp grindline on a flat-ground blade, whereas I'm convexing the bevel to remove any trace of a grindline
Coarse side
Fine side
*600 grit paper
Optional:
