Up for grabs is a pair of one of the best value for money as far as bushcraft knives go. Both are totally new, unused, spotless and never carried before. I have tried to capture their edges the best way I could but it has been very difficult for me to depict them as accurately as I would like. If you see something that doesn't belong to either knife, it is either lint or, it is due to reflection.
Price for both is $65 with USPS Money Order or, $67 with Paypal delivered anywhere in the USA.
1.) Brand New Mora Triflex bushcraft knife. It has a 4.25" Triflex (AKA differentially heat treated) hi carbon blade with a scandinavian grind down to zero edge. The next sharpest thing next to a Gillette razor! It is harder and much more resilient than stainless steel and it will throw a shower of sparks out of a fero rod with ease. Overall length is 9". It has an Olive Green handle and comes in a black plastic sheath. The belt loop can fit belts up to 2 1/2" wide and can be rotated 360 degrees. The sheath also has a drain hole to prevent moisture from staying in it. If you press the knife all the way into the sheath, you will hear a "click". At this point, the knife stays secure in the sheath even in case it is reversed.
Unused, uncarried. Very light, very sharp and differentially heat treated.
2.) Brand New Mora 2000 bushcraft knife. It has a 4.5" blade made of cold rolled special Sandvik stainless steel with a scandinavian grind down to zero edge. One of the sharpest stainless steel knives out of the box! You can literally shave with it! Overall length is 9". The handle and sheath are military green and gray plastic. The leather belt loop can fit belts up to 2 1/2". The sheath also has two drain holes to prevent moisture from staying in it. If you press the knife all the way into the sheath, you will hear a "click". At this point, the knife stays secure in the sheath even in case it is reversed.
Unused, uncarried. Very light, very sharp made of cold rolled special Sandvik stainless steel.
