DA170
Platinum Member
- Mar 12, 2020
Smock CPM-Cruwear Black TiCN Blade Black Aluminum coming soon for $277.50.
Its black TiCN finish hollow-ground blade is precision machined from CPM-CruWear, a Trademark Round Hole and an elegantly understated flipper opener. The flipper action is supported by a pair of special ball-bearing pivot washers and a dedicated secondary detent mechanism separate from the knife's lock. It is paired with a skeletonized handle featuring full stainless steel liners, black hard anodized handle, open-backed construction, and a reversible, tip-up pocket clip for ambidextrous carry.
Edit:added info
- Specs:
- Category End Use: EDC/Collector
- Blade Steel: CPM-CruWear
- Blade Grind: Hollow Ground
- Blade Length: 3.39" (86 mm)
- Length Open: 7.92" (201 mm)
- Length Closed: 4.53" (115 mm)
- Blade Thickness: .118" (3.0 mm)
- Lock Type: Compression Lock
- Handle Material: Hard Anodized Aluminum
- Tip Carry: Tip-Up
- Clip Position: Ambidextrous
- Weight: 3.7 oz. (105 g)
- Made In: Taiwan
Edit:added info
