Nebuchadnezzar
Sxul Tyrannosaurus
- Apr 25, 2008
Took a bit more than a fingernail, but no power tools we needed.Looks like some of that might just come off with your fingernail ... like some kind of residue.
Polish off what's left, if anything left, if it bothers you that much.
If you carry and use it, you'll have worse blemishes than that eventually and those "blemishes" just might take care of themselves.
It's a production knife and you are highly likely to find some "fault" somewhere on a replacement.
Can't ever recall receiving a "perfect" production knife from anyone ... although some are slightly better than others I suppose.
... use and enjoy![]()
Thanks folks, it does seem like more of a hassle to send it back than to polish it and live with it. Used some polish and elbow grease and it came out well enough. Trying to avoid getting the edge finish too far off the nice brushed flat of the bolster. Will mess with it a bit more perhaps.
Just goes to show the advantage of buying from a brick and mortar and getting to inspect the exact knife before you buy. Shop local y'all.
Brass is easy to clean up. Either polish it out, or a green Scotch-Brite pad will take care of it and leave a nice satin finish. Can also use a grit sequence of wet/dry sandpaper through ~2000 or so, and following with polish, to bring all the brass up to a high mirror shine. But in this case, I'd probably go straight to the Scotch-Brite with a few passes. Follow with polish, if you want to. For me personally, I tend to like the muted finish left by the Scotch-Brite.
If I liked everything else about the knife, like the walk & talk, blade sharpness/grind, centering, etc., I'd be very reluctant to send it back for replacement for a very minor cosmetic blemish that's otherwise easily fixed at home.
