No worries. You reply whenever it's convenient and you're in the mood to do so.Sorry about the late replies lately. Was travelling and just arrived in Germany last night.
I’m not certain if I’m allowed to post a link, but I’ll send it to you. You can also find it on their website abrasivetools.eu
and click on “sharpening accessories”. The stones will be at the bottom of that page.
I was told that is PDT’s website. Even though it doesn’t say Poltova or PDT in their domain
Fused minerals see multiple benefits compared to those produced through other processes, such as sintering. Before a sintering process can even begin, the materials need to be sized very carefully in order to ensure the desired reaction. The electric arc furnace does not require such precisely sized materials, however, saving both time and energy—and the resulting costs.
A sintered material also typically has much more porosity than a fused mineral, due to the lower temperatures involved in the sintering process. Since materials in the fusion process are in their liquid state, porosity is reduced dramatically. In fact, the bulk specific gravity of a fused mineral is very close to its theoretical specific gravity, which is not the case with a sintered material.
Purity is another impressive benefit of the electric arc furnace technology. As mentioned previously, the fusion process results in a virtual 100% conversion of the minerals. If we look back at our example of mullite, the same alumina and silica processed through sintering would not be able to achieve the electric arc furnace’s 100% mullite end product. In addition, a small percentage of unreacted alumina and silica would remain following sintering, creating waste and process inefficiencies.
Very interesting reading. If it’s true what PDT states they may work better than some other alumina alternatives, but I heard somewhere, from a guy that used those, that might not be the case. Best way to find out is I order them, eventually. Price is similar to Boride T2 and those perform quite well on my carbon steels. That’ll have to wait though. I bought a bunch of sharpening stones and gear latelyNo worries. You reply whenever it's convenient and you're in the mood to do so.
I see them now. I was confused because I was looking at //pdt.tools/ and I don't see those products there.
The description is interesting. I would suppose these use white fused alumina which is distinguished from sintered alumina, e.g.
But then it says "sintered electrocorundum." These could be solid sintered blocks like the Spyderco, Idahone, and Norton Ascent stones except that it says "ceramic bond" and frankly the grits given wouldn't make sense. I shall have to do some reading to try to understand this.
I forgot to reply to this. Several of my diamond compounds are universal-base, meaning oil/water/alcohol soluble, and I have a 0.25µ diamond spray (suspension) that I believe is water based. However I don't use any of these wet so I don't think this applies to your question.Oh, have you ever used water based compound or suspension/emulsions on non stainless steel? I’m Just curious if it would be an issue, as long as one wipes the blade down with alcohol and the rub some oil on it?
Thank’s a bunch. As always, your answers are super helpful and oftentimes even adress things I never would’ve thought of.I spent some time this morning searching for an alumina production method that uses both electric furnace and sintering but it was difficult because these are so often juxtaposed as above
I will absolutely do that. As soon as I’m out of the hospital again, I will try them on my k390. I’m curious to find out how they’ll work on it. Also compared to my CBN stones.Please let me know if the CS-HD stones work on K390 or if diamond is necessary, and if CS-HD works at some levels but not others, e.g. roughing or finishing
I absolutely meant it and have replied to your mail.Since this is the second time you have offered the cBN samples I see that it was not merely a polite gesture. I accept your generosity again; I'll email my shipping address.
That’s very interesting. I’m not worried to use water based products on carbon steel then. I’ve been getting quite interested in some of the carbon steels out there. There are a few pastes that I’d like to try on some of my kitchen knives, but wasn’t sure I should do that with pastes that have some water content.do almost all my sharpening with water and with very reactive carbon steel I will get surface rust, but not in the area that is being worked (the bevel) as it doesn't sit wet long enough to be an issue. I cannot recall seeing it appear on areas that have been stropped with that universal-base diamond on leather
That’s a great idea!On the very reactive steel I would then polish off the surface rust and do a wipe-down with board butter—a mix of USP mineral oil and bee's wax.
