Expertise Needed: Benchmade Clip
Does anybody know of a low profile clip that will work on a 73x Ares folder without added drilling (three hole pattern)? Color doesn't matter...I just want the knife to ride a little lower in pocket.
Thanks in advance,
Peter
The only fold over clip I'm aware of that's readily available is the one sold at knifekits.com, it's hole spacing would be too far apart.
You may be able to get a custom folder maker to do one for you, but the folder makers doing their own clips is fairly small so you'd want to do some research and be prepaired to pay them for their time and effort.
Sounds like a neat idea, good luck!
The standard Ares clip rides pretty low in the pocket as is.. I really think you are probably going to have to retain the services of a custom maker if you want to pursue this matter. Since the knife is already pre-drilled for the existing clip on both sides, some major changes would have to be done to accomodate a totally different clip.
Good luck with this project. Let us know how it works out. :)
