- Apr 1, 2004
After a liner lock is worn down, why not apply a thin coat of some sort of glue on the blade's tang? This will not only fill in the area where the liner and tang engage, but it will give the liner something to wear against that is (I assume) softer than the liner. So, the thin layer of glue will wear down rather than the liner, hence saving the life of the liner (assuming the liner steel isn't particularly soft). Simply reapply some glue and the cycle continues.
Is this a reasonable idea? If so, can somebody suggest what sort of glue should be used for this?
