Extending the tang
Hello guys, i have ordered a 25cm long k720 (O2) steel blank to make my hidden tang bowie knife, now the problem is, the blade is going to be about 16cm, leaving 9 cm for a handle. I wanted to try and do a pommel nut, but the tang isnt gonna be long as it needs to be, so can i just weld together same piece of k720 after heat treat to achieve the longer tang without making a weak spot? If you know what i mean. Thanks.
Oh and btw the knife will be held by epoxy glue not by the pommel nut alone, its more for looks.
I'd TIG weld it using cooling bars. The effected area won't be over an inch. Won't weaken anything either. Using 309l for a stainless bead.
